Switching From 8's to 10's
it's sloppy but it slams!!
Do you think that’s enough airspace for those 10’s? Website recommends 1.5-1.75 per sub but as discussed, not sure how accurate their specs are.
1.1 cubes is tight. I looked at the SA10's and they only call for one cube ported per sub. My box builder says that the 10's will work in the box that I already have. 1,200 ounces of motor force and a 5K amp seem like a lot for a ¾" MDF box. The subs alone weigh 185 pounds.
the motor weight on the HD’s isn’t the ferrite weight but is the total weight of the ferrites along with the bottom and top plates. The suspension on those subs is on the stiff side and they will need some airspace or the low end and output is gonna be absolutely terrible.
I guess you could try it and then build a new box if you’re not satisfied. I like the SA idea since they require a smaller box.
There is two versions of the SA10. One is 750 rms and one is 900 rms. I was really thinking of just running 4 of these on a 5K. I like my VFL 8's a lot. Why wouldn't I just go with the 10's?
Deff not going to hear much of a difference of the 4 ch amplifiers unless you are going to 100 rms per ch. With 10 watts, its just not worth the...
702
Hello! i have too problems with head units, two cars, old mazda 323f ba and now mazda 6 2007r station. Problem is from lossing quality, poor bass...
998
Yea, I'm running 6S2P. 12 cells total, 2 banks of 6. Resting voltage isn't as big of a concern, it's more about charging voltage. LTO shouldn't be...
Hi everyone... reaching out because I'm a beginner in car audio and need some help understanding how to correctly mount my new radio. I have a...
Bobbytwonames
Trigger Man!
Bobbytwonames
Vegas
djdilliodon!
    May 20, 2024
    May 20, 2024
