Any Speaker ring Makers out there?
  • 6
? why a jigsaw...the speaker rings are going to be mounted on the outside of the door panel exactly where the factory speakers and grill are.No need to cut anything
You are going to mount speaker rings directly to your door panel? Why not under the door panel? Can't you screw the ring to the door and then install the speaker and door panel over the speaker?
No this works for me.... see the factory speakers mount from the inside of the door panel see picture
Can you not mount the speaker inward because of the window or the window motor?
Exactly the reason whyI have done this with my other car and I sealed up the doors and sound-deaden them very well and the MidBass sounds damn good...I thought this out for over 2 months and this will work without using any screws to mount my rings Its going to be sealed correctly
248
342
318
Nobody is bashing anything. Just because I can use stainless, doesn't I should. The bananas I use are 4mm BFA style gold plated copper, pretty...
32
jrouter76
jrouter76
jrouter76
Mount Vernon ,Illinois
jrouter76
    May 12, 2024
    May 11, 2024
