American bass xr or xfl
  • 7
I like slightly overpowering, usually. If anything, the amp is less stressed, because it'll have plenty of power for the woofer, so it should be able to control the woofer better, be a little more balanced, etc. Just set your gains correctly.
As far as power, would a 1500 watts amp be sufficient or should I just go ahead and get a 2000 watt? I have an agm battery, big 3 with ofc wire , replaced my factory 95 amp alternator with a 200 amp alternator,and will be replacing my current cca wire with ofc. (From battery to amp). And I did find a dual 2 ohm xfl on eBay that I bought purchased yesterday.
Sweet !! You should have plenty of power for the sub. Ive even place one of my PPI Phantom 1000.1d on it and she still slamms really nice. Worse case just add another battery if you need a little more supply.
If you want to spend that extra coin on the 2k its up to you. Head room is always nice to have on any amplifier. Ive had a 12inch xfl handle 2k clean
I am currently waiting on TEAM WALMART to ship the pair of 10s 🧐
If you decide on a 1500 or a 2k, Id recommend this brand, as my 2 k is doing some work on a pair of 12s atm, and doing very nice for the $
35425
When did you order?
On Jan 28-2022. Says Preparing order for shipment. Ill prob get an update in the morning about 9am. supposed be here Thursday 😬 .. Good lord Looking around.. Ive got so much audio stuff . LOL. I even picked up some goodies last week that I prob shouldt have.. LOL That Audio Addiction I guess:poop::poop:👀👀👀
Exact amp I am planning to get
Its a great amp man.. And it is strappable too. I may get another possibly to run 4 -12s again later on?? I did get that CT Sounds 150.4 in. Shipping was a little slow do to Pre-order( i believe they are in stock now) so CT Sounds sent me an Email concerned about the shipping delay and gave me an option to not accept the order with a refund or continue and added a PAIR of the BIO 65-4 Mids for the delay. Accepted of course. Im gritting my teeth to get that amp wired up and swapp out my Hertz and throw those mids in to run for a little bit.LOL. Ill get some pics of all the goodies Ipicked up last week in a bit, after I finish up with my car shortly
Same. I am need to stop looking up car audio when I’m sipping . Makes for spontaneous and unthought out decisions 🤦🏽‍♂️
I prob spent like $1k-2500.00bucks last week. My brother is driving my truck atm. Im getting the car together so i can get my truck back to play with some gear. Not concerned whats installed atm and shouldnt get clipped and ruined. He doesnt mind tilting it.. LOL
Lol. I’m not as bad this time of year. Cold outside. But when the weather is nice and I am able to install, it get really bad!!lol
That looks clean.
I picked up the CT Sounds 150.4 to go with it on front stage. The 150.4 doesnt seem any larger than the PPI Phantom 900.4 or the 600.2. Ill get some picks in a bit, of some goodies I got in last week. Get a pick uo the 150.4 next to both PPI amps
Yeah I had torn one down and used my digital calipers to measure coil size ID & OD and winding height and spiders all had it written down and had...
I have 2 of them in around 2.5 cubes per sub, tuned to around low 30s Hz. I think.its tuned a little low. Really low frequencies hit thick and...
Yes, they are definitely beefy. I beat the snot out of this one to find it's limits and it took it rather well. For the abuse I put it through and...
976
Ridinhi
Ridinhi
Winston-Salem, NC
    May 19, 2024
    May 19, 2024
