Speaker/Engine Whine
619Thump
I had an engine whine before but then i fixed it, ended up getting a second battery and rewired my entire system and its back, i checked my amps and stereo, power and signal wires are ran separately, i have a feeling its the stereo because ive had it for years and it was also doing it in my last car, just looking for some help and see what kind of suggestions you guys have to help fix it, ill try checking again with whatever advice yall give
It's common for the Pioneers to blow the Pico fuse in the headunit causing a whine. Normally from "hot swapping" the rcas. You can ground the RCA terminals on the back of it for a quick fix.
It's common for the Pioneers to blow the Pico fuse in the headunit causing a while. Normally from "hot swapping" the rcas. You can ground the RCA terminals on the back of it for a quick fix.
i tried that on my last car and it made it even worse 😂😂 ill try it on this one though and see how it goes
I used to ground all equipment to the same point to avoid ground loops. Got rid of whine in 90% or better of installs.
That fuse theory is interesting. I wouldn't ignore it.
You could prob open that HU up if you are handy and just solder a small 14ga jumper wire in the place of that Pico fuse that is more than likely blown... or take it to a Computer repair shop and get it done for like $40-60 bucks verses buying another unit if you like the radio that much and it functions to your needs? Just suggestion
yea i was looking into buying another HU because i grounded my amp ground somewhere different and it didnt help so its coming from the HU i feel like, i tried the rca ground thing and it helped fix the static but i had the whine with no music coming out the speakers
yea i was thinking of running a ground from the hu to the ground on the battery or the ground where my amp is at
Ive had no issues with 4v Kenwood HUs. You can find one fairly decently priced.. maybe even a 5v hu. i just picked up a nice older Alpine 9585 off DIYMA. I like running the older Eclipse HUs also some 5 and 8v but not as many features asnthe new units provide, but pretty simplistic to run and operate.JVC was bought out by Kenwood a coiple years back and are basicly the same units/models as Kenwoods Same Co. You can find a really good updated HU for $150 for a single din
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
707
I'd be willing to pay for a quality HU, if it meant that I can truly get the sound quality I need. I've seen some aftermarket ones that look...
732
You could do the 8" as a front sub on its own amp and use it to bridge/enhance the gap between your 12" in the rear to the midranges
553
619Thump
619Thump
San Diego
just call me KeV
    Apr 18, 2024
just call me KeV
    Apr 18, 2024
