Design ideas for 2 sundown u series 15’s in 3.0 cubic ft tuned to 32 hertz
Are you looking for a design or just advice?
Enclosure help usually involves a lot more info than you've given. There used to be a stickied thread in enclosure help listing what would be best to list so whoever chimes in has the info needed.
Advice?.. I'd say check it out.
I’m looking for a design.
Vehicle : 2006 Hyundai Azera limited
Location in the vehicle: backseat
Space available (Length x Width x Height):
Subwoofer make and model: sundown audio U series dvc 4 ohm
Subwoofer size: 15”
Number of Subwoofers: 2
Type of Port (Kerfed, Slot, Aero, etc.): I’m going for aero or kerfed port
Is your goal SPL or Everyday Music?: kind of an in between on spl and everyday I’m looking to build a hard hitting system but nothing too crazy cause I will use it everyday
Tuning Freq (Hz): 32 hz
Dimensions would help. It sounds like your going to have to wall it off to do it right Whats an Azera?.. subcompact?
This went into a Tahoe...
Nice on a decent 5k if I do say myself
Yea it’s basically like a Hyundai Azera I’m running a 4500 watt amp with a lithium bank and the biggest box dimensions I could do and doesn’t have to be this big but can Is L: 42 inches W: 19 inches H: 27 inches
But if I did a trunk build I could fit a bigger box something more like that build for that Tahoe
If you got 42w x 37d and 19t why not trunkwall it? Subs/port forward sealed off from the trunk. Its more about install when your doing a trunk build in my exp. Trunk boxes do ok but 2 15s in a trunk? I say face em forward just do some prep work 1st...
Make it slide-in and solid. Deck too. Jmo.
Best I got
That's a big ol box man... why not give us a realistic measurement? Like what fits in there maybe? You know... the trunk opening and what slides in? What you think you got and what's available are 2 things unless you want to build it in there... 🤣 Or maybe it fits pulling the seats out and loading it from the cabin?.. you tell me. Its your car after all. Its a B when door size becomes a consideration tho.
Subwoofer size: 15”
I can design you an enclosure for $20. The design comes with a 3d model, response graph, port velocity graph, and comprehensive cut sheet. Message me if you're interested.
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
518
Buddy of mine somehow managed to get small MDF boxes set into the rear doors on his previous truck, think it was an F-150. I can't remember...
815
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
Alex Leslie
Alex Leslie
Lake Charles LA
20 hz bass machine
MrG
    Apr 18, 2024
MrG
    Apr 18, 2024
