looking to use for one 10 inch sub
outside box dimensions will probably be at max 20 inches wide 15 inches tall 6 inches depth
Box will be glued
box will be predrilled and use wood screws also
really 2 questions
1 I have limited depth space behind the seat of a tundra crewmax
can I use 1/2 inch with proper bracing?
using 1/2 inch material really opens up the options on the subwoofers I can put behind there
if we use 1/2 inch material I can use a double baffle on the front. Air space is really not the issue. Just the mounting depth.
2 what material would you use
MDF yes, no
Sanded Pine plywood yes or no
Birch ? is birch worth the extra cost yes or no
With the box size being small is there really no difference in the material strength or quality so just go with lower cost material?
Box will be glued
really 2 questions
MDF yes, no
