Different Car Speaker Sizes for You
MichaelEvanchuk
When you want to measure car speakers, size matters the first. There are various car speaker sizes for different uses. Let's have a look at the different car speaker sizes and decision is yours which one will be best for your car.
4X6 Speakers
This size speaker is better for your dash and produces good bass and sound for your car audio. It has low frequency and it can boost your car sound easily if you can add external amp with it.
5.25 Speakers
These small size speaker is mostly popular to use around your car's back doors or sometime back dash of your car. They are renowned to produce perfect sound that helps you enjoy your ride properly.
6.5 Speakers
It's bigger than 5.25 and can produce bigger bass output with low frequency. When you are listening music using these size of speakers (6.5 Car Speakers), you will be able to get yourself love with the size. Special for louder sound output.
6X8 Car Speakers
If you are planning to add aftermarket speakers in your car, 6x8 can be the best choice in terms of better sound output and such on. It produces significant sound output, better bass, better sound quality and much more.
6x9 Speakers
It's the bigger size car speaker till now. It has punchy bass, can handle higher frequencies, with in-build tweeter that further increases the speakers sound quality and so on.
There are many other speaker sizes available in the aftermarket. It's up to you what you are going to select depends on your demand, budget, expectation. Hope you will have a good journey.
Which size speaker are you using at the moment? Let me know your opinion
I only use king size speakers.
26957
Dont know why we gotta hate. I don't think Michael was trying to be deceitful or spread misinformation. Constructive criticism goes a long way. Size alone doesn't decide what a speaker will play well. Granted an 18" sub will play low frequencies much better than a 1" tweeter and most of the time you can saftey assume what a speaker will play well based on its size. That doesn't mean a speaker cant be designed to shine at almost any frequency despite its size.
Not a person but nothing but a bot as Pop said. Wasn't degrading anyone just pointing out the facts on him. This bot comes back every couple of months and posts BS opinions out of nowhere including on other threads.
That's great!
You listed 4x6 as "good bass" and 5.25 as rear fill. 4x6 has less cone area than a 5.25.
it's only my opinion
Opinion discarded.
really?
I see our Russian friend is back with more BS opinions!
ahhh!!
up to you
If you knew some of the history and posts you would understand mine.
that would be better
Weirdest bot ever.
real human here
as I said real human here
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
Hello back, For those who are also looking for a problem of sh*t bass, after such a long time of fighting, I come to a conclusion that the...
17
As long as you don't overpower them, there is no danger of harming your gear, once you get a new sub so they are both the same, you will likely...
THIS IS THE SAME AS THIS: One coil + to the other coil - (on each). The other + & - to the terminal block. Terminal blocks wired straight...
MichaelEvanchuk
MichaelEvanchuk
United States
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
