Computer building, I am
@Coolhand20th , @LsGuy, the highest temp I've seen on CPU is 65C, that was while running windows defender and malwarebytes full scan at once. 65C is about where all fans go MAX level, so it seems to hold there pretty strongly. Does that temp sound right to you guys? At idle, depending on room temp, I'm at 32-36C with windows open, according to my Ryzen Master.
25642
I run 32gb of memory right now and in the next build will be going up to 64gb most likely. Glad that program worked. Even got my dad to look into it and said the same things that it was slick as hell and he liked it.
Glad I could help and anything else you need you know I'll try to help if I can!
I have my monitor on Freesync. I can't control brightness outside of the actual monitor menu, it disappeard. I can't control it through Radeon's graphics app (update app for everything), nor can I control it through windows display, do you know why it disappeared? I have super sensitive eyes and I have my monitor turned all the way down and the white on some web pages is still really bright.
I use a program called F.Lux which can control the brightness. Been using it for years with good success as I like the brightness down. Can be set for certain hours of the day and everything plus it is free.
I honestly don't know much about AMD Drivers anymore. They are known to be kinda crappy in all honesty.
Nvidia has their GeForce experience for drivers and shit, but then you can right click on the desktop and open Nvidia control panel to adjust brightness and fps and shit. Check for that with amd. Also, why is your ram at 2933? Did you enable the bios profile? Zero reason you can't run your ram at full speed with that ram and motherboard.
I figured it out thank goodness
I just did 2933 because that's around where overclocking starts. Just playing around with it
You have to do custom color inside of Radeon's app. It actually works well. I can't look at straight white so I've got the screen really dark but high color saturation and the color more blue-ish, where the whites look somewhat blue. Helps my eyes a lot.
i pray that god reads this back to you. in these trying times im blessed to be able to live on cd's and bonds i also was blessed to be the owner of almighty installs llc and almighty transport llc.....ask your mom
There is no god. You drive hoopties, have no life, and nothing better to do than check everyday to see what I post just to dislike it. Worthless.
Now get the fuck out of here and quit ruining Bucks thread...
Buck
little alien on campus
Buck
Inside of a pyramid
ThxOne
vegang
    Jul 1, 2026
vegang
    Jul 1, 2026
