Computer building, I am
I know these are hard to see, my iPhone camera is bad, if I hadn't said that enough.
25242
You are getting them from AMD right? Maybe try a previous driver and see if it works.
Everything now is just what came with the hardware, nothing has been installed. And yes, I did, it made my screen look terrible. Idk if I had a conflict with another driver or if my TV is so low pixels (not full HD), that it messed up the settings.
Download the graphics driver for your card, on the desktop go into properties and make sure your resolution is set correctly.
Also for the record, I have never let thermal paste sit longer than 10 minutes before booting, and I have never heard of this being practiced before. Interesting concept.
I've also never spread thermal paste. For one, you just don't need to spread it. And 2, if you don't take great care in doing so, you can actually leave bare spots on the cpu. I just use the drop in the middle and let the heat sink spread it for me. Those lines on your cooler where paste was missing is one of 3 things. 1, it got pulled off as you removed the cooler. 2, uneven clamping pressure from the cooler. 3, uneven surface of either the cpu or the cooler.
Thermal paste on the side in excess amounts should be avoided, however it's only an issue with conductive thermal pastes. I haven't used the stuff you are using, so I cannot say if it is conductive. Many these days are not.
Buck
little alien on campus
Buck
Inside of a pyramid
ThxOne
vegang
    Jul 1, 2026
vegang
    Jul 1, 2026
