Wondering what my setup would meter
sounds_explicit
Bored and its raining, thinking about what my setup would meter. But dont know anyone with one or a shop around that has one. Maybe based off personal experiences what would you think it would meter
2 american bass xr12's at 1 ohm on a taramps bass 3k. 350 alt voltage reg ,plat agm, northstar agm 31 pro. Deciding on if i wanna go with a 5k to combat rise. But based on what my sub stage is what would be a normal meter? Box is alkost 6 cubes before disp. Tuned to about 33 hz
I got some new welding wire coming in and I'm gunna replace my main run as it's old but everything else if less than a few months old. I think j may have found someone local with a meter so when I get it done this week ima gunna try see what it does.
I got 2 in there now. I shifted a magnet on 1 on accident. But the box is big
I had 2 xr12s (still have them on a shelf) on a sq2200.2 and I’d guess my setup was 135ish maybe idk i like the xr’s that’s why I’ve held onto them but they aren’t exactly spl woofers esp if you look at the ts specs
Right. I had the xfls before I went to the xr's I miss the xfls like crazy but the xrs sound way better and hit the notes much better . I may go back and grab 2 of them one day lol. I'm a dummy I had 2 blown ones and I just scrapped them. Motor and everything in the trash kne day after holding onto them for a year. 🤦🏼‍♂️🤦🏼‍♂️
I have a 2006 Mustang GT and the alternator amperage is 135. I'm running 3 amps totalling 1600 amps, driving 2 subs, 4 - 6x8 and 2 - 6.5. Ive...
Ive seen 3 370s in action at a couple Audio shows with a massive battery bank in Austin
741
566
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
968
sounds_explicit
sounds_explicit
cleveland ohio
sounds_explicit
    May 12, 2024
    May 11, 2024
