Bezzle
Hey gang. First post in here. I have a question I could use some help with. What are some ways to stabilize the voltage in a system?
I’m unable to get a dual pulley setup for my vehicle, so I can’t have more amperage coming into the system than what’s coming out. My Alt produces 320 (largest I could find for my vehicle), the system draw (at peak) is 470. I do have two batteries that cover the wattage by 130%.Have more amperage supply than the amperage draw.
Well yeah if you know what you are doing bro lol. Not to mention space requirements. I hear you though.Making brackets to add an extra alt is easy af.
Yeah space is the main issue for sure. Can always get rid of the AC.Well yeah if you know what you are doing bro lol. Not to mention space requirements. I hear you though.
All depends on how bad you want it lol. My power steering pump is the same size as my alt and sits right below it. Hmmmmmm.Yeah space is the main issue for sure. Can always get rid of the AC.
I've had plenty of vehicles with no power steering.All depends on how bad you want it lol. My power steering pump is the same size as my alt and sits right below it. Hmmmmmm.
I'm to young for that (27) and I only have one car so there is no way I'm doing that.I've had plenty of vehicles with no power steering.
Lol, what car do you have?I'm to young for that (27) and I only have one car so there is no way I'm doing that.
2004 audi a4 quattro. Tough to work on but its reliable. I've had it for 10 years now. Just recently replaced the steering rack and outer tie rod ends. Other than that just general maintenance. It's a ***** to work on though I'll tell ya that lolLol, what car do you have?
I have a singer alt. It wasnt cheap lol but I believe it's like 220amps. I'll eventually be running 4-4.5k, but before that happens I'll have a northstar group 34 agm batt with 6 ultacaps (1 bank). That's a while from now though. Atm I'm only running around 2500 watts.Yeah I'd keep the power steering then. Somebody can or does make an alt for you. Probably isn't cheap tho.
