Ol school 15" cerwin-vega Stroker encloser
You may have to go into the trunk at an angle ... you wont be able to do ported or vented ...so really the vhf only choice is sealed . Youd need a 3 cu ft sealed enclousure with a double baffled front at about a 45 degree angle so you could install the sub . If your mounting the amps on the rear of enclousure . The rear board would need to be double baffled as well and mount amps to rubber isolaters to prevent damaging vibrations to the amps circuit boards ....
Thanks i did build a ported box. I will post specs
21534
Dan Henderson
Dan Henderson
Plymouth, Indiana
Dan Henderson
