Ol school 15" cerwin-vega Stroker encloser
  • 2
You may have to go into the trunk at an angle ... you wont be able to do ported or vented ...so really the vhf only choice is sealed . Youd need a 3 cu ft sealed enclousure with a double baffled front at about a 45 degree angle so you could install the sub . If your mounting the amps on the rear of enclousure . The rear board would need to be double baffled as well and mount amps to rubber isolaters to prevent damaging vibrations to the amps circuit boards ....
Thanks i did build a ported box. I will post specs
21534
Marine speakers would be Ideal as stated and Coax. Polks would work very well. First choice of mine would be...
339
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
  • Locked
Clearing out storage. $75 + shipping. Located in Carlsbad, CA. Pick up OK. Shipping weight is probably around 13 pounds. Slightly to deep to...
Dan Henderson
Dan Henderson
Plymouth, Indiana
Dan Henderson
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
