Recommend a 12" sub please.
ghart999
Number of subs preferred: 1
Size preferred (if configuration allows): 12
Budget:300
Power to be used (which amp(s), include which resistance): 600W @ 2ohm
Space available (take measurements, do not guess): 4cf
Goals: nice SQ and kick drum impact
Listening habits: 80% rock / 20% everything else
Preferred brands/subs/whatever: doesn't matter
I would like to port if it gets me lower frequency than sealed. Going in the trunk of a Hyundai Sonata.
Thanks all.
Do you have an amp already? $300 is a bit higher than a budget sub. Could you displace money budget on sub to budget on amp?
based on your ask by watts
Looking to spend around $600 - 700 max on sub and amp. But the amp needs to be 5-channel. I don't have the room for 2 amps. Was looking at an Kenwood Excelon 4x50 + 1x600. I am open to more suggestions on both. I keep hearing decent things about American Bass. I have been out of car audio for about 6-7 years, so the name means nothing to me.
How much physical space do you have? I ask becuase take a look at these examples below:
5.433 x 1.929 x 4.763 inches
8.98" x 2.76" x 6.22"
if you run your wiring smart the footprint of these types of amp may actually be smaller than a five channel
Is that brand decent? I suppose I could go separates. 1200W @ 1ohm could be beneficial with it being so small. But almost seems too good to be true.
It’s a good brand bro, it’s full bridge “Brazilian” technology. Make sure you have a good agm up front, Do your big 3, use nice and thick power wire for your sub amp (1/0 to 4 guage reducer ends) and make sure your voltage is strong and all will be good. That power opens up the door to more boom and some solid budget options. There’s an md1800.1 that is like 2” longer but Same width and thickness for like 20$ more that will give serious boom.
I’ve never owned them but have heard a lot of crossfire products and like them a lot.
22
One thing I’ve noticed about reading reviews is those who cannot spell offer very colorful and misspelled adjectives to describe products. Take...
Sensitivity is usually measured 1watt 1 meter. I'd go by that. Higher the better on subs too. Less power to get louder. Every 3 DB gain is like...
114
I've been a fan of the JL shallow mounts, and have actually heard a decent box with some Pioneers but the Focal are pretty darn good. The JL TW's...
239
ghart999
ghart999
Denver, CO
Rhunt12356
slater
    May 2, 2024
slater
    May 2, 2024
