no, you are better off with dedicated midrange/midbass drivers with high sensitivity ratings and just the super tweets. No coaxials if you plan on using super tweets. Again coaxials have tweets on them super tweets are tweets, they play the same frequencies buy they reproduce those frequencies differently and they are in different locations which is an acoustical hell of a mess.So would I be better off getting a 2 way coaxials that has a 1” tweeter that matches the size of my super tweeters?
Because it’s hard for me to find 5x7s or 6x8s that are really good. Do u know any that are good with 1” tweeters?
Those are out of stock thoughbridge your rockford amp to these, they'll handle every bit of that rockford 2 channel bridged mode.
Home
PRV Audio 6MR500-NDY-4 6-1/2" Neodymium Midrange Woofer 4 OhmThe 6MR500-NDY-4, from PRV Audio, is made to be a class-leading midrange woofer in the pro audio realm, as well as high output car and home audio, thanks to high-power neodymium radial slugs that immerse the voice coil in a strong...
then get a 100 x 2 channel amp for the super tweets and voila you'll be golden.
no you need 4 ohm drivers because your final minimum impedance is 4 ohms. amazon has those same speakers. All you need to do is focus the front stage. As for your tweeter amp you can just get a pioneer gm 8704, its a 4 channel but its cheap as most good 2 channel amps with a lot of power left over and extra channels for anything you want and its 1 ohm stable so 2 channel bridged easy. the previous gen tested at 120 x 4 rms on the amp dyno so more power than your rockford.I can only bridge it at 4ohms. I would need 8 ohm mid bass drivers
But I’ll have 4 4 ohm loads that need to be ran on 2 channels since it’s being bridged on the 4 channel amp. U can only bridge 4 4 ohm loads to 8ohmX2 and 2ohmX2no you need 4 ohm drivers because your final minimum impedance is 4 ohms. amazon has those same speakers. All you need to do is focus the front stage. As for your tweeter amp you can just get a pioneer gm 8704, its a 4 channel but its cheap as most good 2 channel amps with a lot of power left over and extra channels for anything you want and its 1 ohm stable so 2 channel bridged easy. the previous gen tested at 120 x 4 rms on the amp dyno so more power than your rockford.
Amazon.com: PRV Audio 6MR500-NDY-4 Neodymium 6.5" Mid Range 4 ohms Pro Audio Speaker 96dB 250 Watts RMS 2" VC: Musical Instruments
Buy PRV Audio 6MR500-NDY-4 Neodymium 6.5" Mid Range 4 ohms Pro Audio Speaker 96dB 250 Watts RMS 2" VC: Monitor, Speaker & Subwoofer Parts - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
