Crossover settings
  • 2
Gunk
237
37
Ohio
Im setting up crossover on amp for a couple Beyma 8s. The 8s have a freq. response of 65-6k hz.
The proper setting on my amp would be to set the hpf at 65hz correct?
Just wanting to make sure.
Your gonna have to listen to them and see how you like it. You could start at 65, but depending on how much power your giving them, you might have to bump up to 80 or even 100... just listen for the distortion or bottoming out
Thanks.
I assume these will take a "break in" period before they are working at their best. Should I avoid giving them max power during this period? They are rated at 250 RMS.
19423
If I'm not supposed to give them full power for a while, was wondering if I should wait to hook them up bridged to ensure they don't get too much power too early.
Thanks.
Personally I dont think it matters. Just set your gains clean is what matters. No clipping. Just listen to the speakers, they will tell you if they are straining or not. You might set your HPF at 100 for the first week and get a feel for the speakers and how they sound, then lower the HPF and listen for signs of stress.
When I ran 8" midbass in my doors, I used the HPF on the radio, on rock it would stay at 63, rap I would bump it up to 80. But if I didnt have the sub installed I could drop it down to 50 but not turn it all the way up
Was just playing a 80hz test tone at about 30% power. Was checking for rattles and such in the door. All of a sudden the sound just changes from being clean to sounding like its garbled or underwater.
Did i do something wrong here? Is it bad to play a test tone for 30 seconds straight?
I think this speaker just died. Merry Christmas to me. Lol.
For the front and rear speakers set the high-pass filter around 80-120 hz depending on what sounds better with over driving the speakers (you'll...
874
almost looks like it could be 180 degrees on one, and the other is about 120. IF SO, it makes me think the 180 under there would be the reason...
14
By Cook Cluuck Book 98.. You must have sound to be good before you can have decent sound. System is measured by how many ants move one piece of...
14
While we call the M3 Carbon our midrange it is actually a wideband loudspeaker capable of playing from 125 Hz up to 20,000 Hz. We recommend a...
Gunk
Gunk
Ohio
Gunk
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
