Building a System! Any thoughts?
I've never used a Taramps amp before. I would feel safer with the Vfl2k. How about an American Bass 120.1? Almost 2,000 rms @1 ohm.
The amps you mentioned are more resilient to shit electrical so they’re less likely to protect but they draw a lot of amperage. so just ensure your electrical is sound and a taramps is a good solution. A 120.1 is a great amp, if you can find one I’m jealous but they don’t make em anymore and they do pull quite a bit of amperage as well.
The math...90 amps multiplied by your voltage 13v is 1170 but your bug may consume 50% of that amerage so it’s really half of that. 585 watts
You’re a good 100 amps from having electrical for a korean 2k
I need something like this? He hit 141 with two L7's.
O.k., I did some research. What are your thoughts on a Taramps MD3000.1 4 ohm amp to push the AB HD15d2 at 4 ohms. It's roughly 3,000 rms. These are the specs. I highlighted the key parts to me. Thoughts?
The are great amps. I have had 11 Taramps amps and loved them all.
I’ve seen HD8000s dropped to 9 volts multiple times and shut off due to low voltage protection and they just kept coming right back on with no issues. The MD amps are even more better built. I would always wire as low as you can to combat impedance rise and if it’s too much power just lower the gain.
I fried a chine
Bass line is even more efficient but costs more
What I mean is draws less amps than the md
130amp
18492
I will most likely order the MD3000 4 ohm model. 3,000 watts rms @ 4 ohms @12.6 volts. Now, what do I do with the Orion XTR2500.1? It's never even been installed. BTW, what does, "I fried a chine" mean?
I fried a Chinese amp. the taramps on the same electrical (but with better ground points) has worked without a problem.
When I say fried I mean there was visible smoke coming out lol
Again don't buy the 4 ohm. Buy the 1 ohm and wire to 1 ohm.
If you ever went to sell the amp you will have a very hard time selling a 4 ohm version over a 1 ohm.
Not to threadjack but would you run 2 sa12s at .5ohm with the taramps bass line amp?
Still have my 2ohm dvc sa12 that I would like to use so I figured I can purchase another 1.
I know I can wire to 2ohm which is like 3500w with bass 5k
But the 4 ohm draws less current, which is what I need with my electrical in my bug.
But the 4ohm will draw less current, which is what I need with my questionable electric in my bug. Not worried about selling the amp.
Bobbytwonames
Trigger Man!
Bobbytwonames
Vegas
danielbea122
