2013 Chevy Equinox LS - engine/accessory noise coming through factory 1/8" input
  • 2
djhath
I have a 2013 Chevy Equinox LS with a factory stereo system. I do have aftermarket amps and speakers installed, but the stereo itself is factory.
I recently purchased a Scosche bluetooth adapter to plug into the 1/8" input because the factory system will do bluetooth for phone, but not for audio.
I am getting noise through the 1/8" input while using the bluetooth adapter or connecting my phone, but through the radio, CD, or the USB input. The noise is reminiscent of a whine that appears when you either press the accelerator or turn on the air conditioner.
I think I may be **** out of luck with the 1/8" input itself, but was curious if there was anything that can be put in-line between the bluetooth adapter and the 1/8" input to eliminate the whine/noise.
In professional audio, for example, I know there are things you can put in-line to eliminate ground hum or other such noise in the signal path.
Any input is greatly appreciated.
Great one
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
Anyone? Anyone? Looking at the audio control d 6.1200
in advance i already a have a sub skar zvx hooked to a 1500 watt ab mono so take into account there will be a sub may or may not change out the...
Excellent for good sound stage and imaging, don't expect it to move your mirrors or anything. Honestly with what you're trying to do just doing...
12
djhath
djhath
Acton, MA
AddicLee
DEW123
    May 7, 2024
DEW123
    May 7, 2024
Latest topics
