IA 10.1 ....1/2 ohm daily?
Look at it....does it say 1/2 ohm stable or 1 ohm stable?
So you don't really know ?
Because I know some amps can run just fine at lower than rated ohm load,while others pop very quickly.
I guess I'm asking for input from someone who has actual hands on experience with this particular amp.
So you don't really know ?Because I know some amps can run just fine at lower than rated ohm load,while others pop very quickly.
Neither do you. We'll wait for someone who has ran those amps....
IA amps laugh at 0.25 lol
Idk about these newer ones tho, particularly the smaller ones. 0.5 should be fine. But you accept the risk
It also lowers the amps efficiency and raises the current draw.
5
344
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
217
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
881
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
10
966
sprinklerman
sprinklerman
ok
kr15
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
