WTS Orion Extreme 400
  • 2
GAMEOVERCCA
INCRIMINATOR AUDIO
1,860
Hickory NC
Orion Extreme 400
Good condition, works like new, Will give 30 day warranty from day you receive amp, here is some specs,
Power Output 4 Ohm Mono: 400 Watts
Power Output 2 Ohm Stereo: 200 Watts
Power Output 4 Ohm Stereo: 100 Watts
Frequency Response: 20Hz to 20 kHz 0.25 dB
Linear Bandwidth 6Hz to 50 kHz 3dB
Signal-to-noise ratio full bandwidth @ rated output power: >100 dB
Damping factor @ output connector full bandwidth >400 at output connector
Input sensitivity: 200 mV to 5 Vrms
Fuse type: (2) 20 AMP ATC
Low-pass crossover: Continuously variable
Low-pass frequency range: 45 Hz to 5 kHz
High-pass crossover: Continuously variable
High-pass frequency range: 10Hz to 1 kHz, 100 Hz to 10 kHz
High-pass "Q" range: Continuously variable from 0.707 to 3.5(0dB to 10dB)
Dimensions: 12" x 10.25" x 2.25", 305mm x 260mm x 57mm (L x w X H)
$160 Shipped and insured
Included in price
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
732
I have created a post with all related information regarding the build under this link: https://www.caraudio.com/threads/2000-camry-build.614208/
50
Yes, they do. As for the Taramps remote control, it is for use with the EQ they sell, not as a remote bass knob. They are not very sophisticated...
24
4K
GAMEOVERCCA
INCRIMINATOR AUDIO
GAMEOVERCCA
Hickory NC
GAMEOVERCCA
DEW123
    May 7, 2024
DEW123
    May 7, 2024
