WTS Orion Extreme 400
GAMEOVERCCA
INCRIMINATOR AUDIO
Orion Extreme 400
Good condition, works like new, Will give 30 day warranty from day you receive amp, here is some specs,
Power Output 4 Ohm Mono: 400 Watts
Power Output 2 Ohm Stereo: 200 Watts
Power Output 4 Ohm Stereo: 100 Watts
Frequency Response: 20Hz to 20 kHz 0.25 dB
Linear Bandwidth 6Hz to 50 kHz 3dB
Signal-to-noise ratio full bandwidth @ rated output power: >100 dB
Damping factor @ output connector full bandwidth >400 at output connector
Input sensitivity: 200 mV to 5 Vrms
Fuse type: (2) 20 AMP ATC
Low-pass crossover: Continuously variable
Low-pass frequency range: 45 Hz to 5 kHz
High-pass crossover: Continuously variable
High-pass frequency range: 10Hz to 1 kHz, 100 Hz to 10 kHz
High-pass "Q" range: Continuously variable from 0.707 to 3.5(0dB to 10dB)
Dimensions: 12" x 10.25" x 2.25", 305mm x 260mm x 57mm (L x w X H)
$160 Shipped and insured
Included in price
GAMEOVERCCA
INCRIMINATOR AUDIO
GAMEOVERCCA
Hickory NC
GAMEOVERCCA
