Audioque 3500.1 @ .5 Daily?
i see lots of people runing ap amps @.5 no prob i was using two 3000.1ds daily @.5 for a few mounths then one went up in smoke. they put out plenty of power they take plently of power to run and they sound fair.
and what about audioque amps?
or why not just get a xx-hercules at .5 ohm since they have been used several times successfully at that load with no issues.
With the electrical you will have no problems at .5 daily. I have a guy running his at .25 daily with the same electrical as you and we tested the same amp in 2 other vehicles below .5 daily and they all worked fine for it.
Ahh sounds good to me. Thanks for all the input.
Yes, they do. As for the Taramps remote control, it is for use with the EQ they sell, not as a remote bass knob. They are not very sophisticated...
24
4K
NADBL is the org that we get up here in the northeast, they do some shows in Ohio and upstate NY and into Canada, might be close-ish to you...
36
4K
If you wire it to 1 ohm it will make 15,000W You should expect to pay at least double the MSRP of that amp in electrical upgrades to properly...
Just playing around. He's not even turning it up...
37
5K
TheFiverMan
TheFiverMan
Louisville,ky
skittlesRgood
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
