rearview mirror wont stay on
well i have to keep it cause my compass module is attached to it for my messege center. as for the glue...it was a kit i bought from pepboys....i think i might go back and buy the better one.
i think it might be falling off cause of the extra weight of the compass controller.....idk
Make yourself a metal bracket that attaches to the roof and comes down through the headliner, bolt the mirror to that.
My mirror spontaneously exploded one day while I was driving, two pieces flew off and one hit me in the face nearly missing my eye... lol
The problem with most people is they keep tightening the set screw. The key is to keep it loose. Let the actual mirror absorb the vibrations and don't make the glue joint at the glass take it. Sure it will have to be readjusted but it will stay A LOT longer.
It's supposed to be, that you're not supposed to be able to mess with/adjust your GPS settings while you are driving, because it's a hazard. A...
859
I did mention earlier that you might damage the glass. This sort of thing is not uncommon.
14
This will be an interesting issue to find out. Subscribed!! Are you running components? Ive had some caps blow in Passive xovers and a little...
921
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
Sleeklsc
Sleeklsc
inkfx
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
