zx1000 with a w7. good setup?
jl amps are expensive. what if i ran say a zx 1500 to it? or some other 1500 wrms amp?
that might be a little much since most of the zx1500.1's i've seen birth around 1700 watts. @ 3 ohms you'd still probably get around 1200~1300 wrms? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Well i've seen many a W7 take that kinda power and keep going successfully.
why does JL do that? 3ohm SVC?
so you'll buy their amps that do their power at 3ohms.....
JL bastards.
is it a single 3ohm or dual 3ohm? if you're lucky its a dual 3ohm voice coil sub and you can get a 1.5ohm load and get a 2ohm rated amp.
if not get a 1500w @ 2ohms rated amp and after imp rise you'll be okay.
JL bastards.
x2. Its just a keep here shop here deal they do. Just like if you work on cars, they automaker wants you to buy FORD, repair with Ford. Just like I heard the new BMW have a 2 hood over the engine, so if you life it you void the warrenty, I hate companys like that
s_mooj
Banned
s_mooj
british columbia
nauc
Doxquzme
    May 14, 2026
ThxOne
    May 13, 2026
