Zero midbass....suggestions?
arhoneyc
I recently put this system together in my Accura 96 and its really lacking in the midbass area. Any suggestions?
Kenwood Excelon KDC-X395
2 Rockford Fosgate Punch P3D212 12" Dual 2 ohms
Rockford Fosgate Prime R500-1 500 Watt Mono Amplifier
Rear*Polk Audio DB651s Slim-Mount 6.5-Inch Coaxial Speakers*
Focal Access 165 A1 Component Set
rockford fosgate*punchp400-4 400w 4 channel
JBL MS-8 Signal processor
Wow thanks for the quick replies. I'll take a pic of them today but I have them in the q-logic kickpanels...which are def not sealed very well. I can easily put my finger in behind it. I was thinking about switching to my doors if it would give me a better sound.
I think sealing the kicks would do better for the Focals
pickup1 could I do an extra midbass in the door with the same amp I'm using? If so any suggestions on what to get?
hispls that's almost what it sounds like...I know the speakers are capable of it but at certain frequencies it just cuts out. I'll flip the phase today and see if that helps
any suggestions on how to seal those q-logics?
so I would buy was midbass speakers...ditch the focal crossovers and get some 3 way crossovers? suggestions for what brands or models? also I seen several people said something about sealing my door....can someone explain? thanks for all this help!
you do not need a 3 way set to get good midbass.
You need to take some sheet metal or wood or something sturdy and seal up those gaping holes in the door frame. Also, you'll want some deadener on your doors.
arhoneyc
arhoneyc
United States
trumpet
