Your car's resonant freq?
In all seriousness...from my wall building experience (I've built/had a hand in building a few), the only way to get em loud is to test test test...for one wall we had 4-5 different baffles (anywhere from 4"-10" thick)and ~5 or so different angles for the back wall and would swap em in and out until we got what worked best..
That's quite an investment in Mdf.
I am also concerned about weight. In a small car, does it cause structural damage because of the wieght?
Yep...was a ton of MDF...used 1" MDF. Even used 2" Trupan in a wall in an old Montero we did...sawzalled off the roof to make room for the wall, then welded the roof back in place //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Not ready for that type of commitment. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
why are the baffles that thick? is it because just to hold the weight of the woofers?
in my escort we walled it off with 2 sx 15's with 9+ cubes of 3/4" mdf and it lowered the rear an inch or so. The car also acted wierd, the idle acceleration increased.
in all setups I've had in my car the peak note is always 40 hz, had a box tuned to 38 hz, then 40 hz, and currently 32 hz, and for some reason 40 hz still shines.
good lord what an explosion of..... well... alotta junk //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
if you decide to go down the road of "sealed box first" testing... you HAVE to use a .707 butterworth alignment, sealed...
why .707? because one of its characteristics... is a 12 db per octave rolloff below F3... I think its F3... we'll try it..
now its been well documented that 99% of vehicles exhibit a boost of roughly 12db per octave starting at the corner frequency, which is determined by the size of the cabin, and its characteristics at higher pressure. most corner frequencies are in the 60-80 hz area....
so simple math... 12 db per octave - 12 db per octave = 0ish... flat response down to Fb.. which in theory will allow the peak hunting to begin...
but there's a couple giant flaws..... one... as stated previously... most vehicles do not have any big peaks.....
two.... as pressure increases.... the vehicle will flex, and leak... and that throws a loop into the frequency finding...
so in short.. sealed box testing at a db level lower then what you'll be using... is a waste of time... but by all means go for it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
now... onto box efficiency...
that's what you wanna spend your life testing.... finding the perfect combination of vehicle, port, volume, and wooferage....
unfortunately... there's no set way that works for everyone.... which is why "test, test, test" is usually said 20 times in the course of a thread like this...
speaking for myself... my grand prix walled off, didn't care what it played... it played exactly what I designed it to play.... and I've adjusted to play nearly every frequency from 30hz, up to 68hz, with no problems..
depending on the mic placement, certain tuning arrangements did better, due to wavelength propegation, and cancellation.. which again.. is why I've spent soo much time testing....
Loyd L.
45auto
45auto
Buffalo, N.Y.
dleccord
BP1Fanatic
    Jun 2, 2026
BP1Fanatic
    Jun 2, 2026
