Your box size?
  • 5
wu36ca
It seems like all the boxes I hear about on these forums are at least 2.5 ft^3. I have a box that is 2.71ft^3 gross and the most common comment I get is how big the box is. It may just be the fact that the depth is greater the width that makes it look big. But I was surprised that even the owner of the shop I go to commented on how big the box was.
Well ... it depends 100% on the sub you are using, the application, and the size of the woofer.
What sub are you using, ported? sealed? 8", 10", 12, 15, 18" ??
My sub is a 12 in a ported box tuned to 32 hz. Its an SE. My whole point really was it seems like people build these huge boxes, but what I thought was a small box gets a lot of comments about how big it is.
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
40-85l is about the size range most high powered 12" woofers will want for a box. You should use manufacturer suggested box specs unless someone...
I would like to a bandpass box wherein the subs are facing each other and each have their own sealed enclosure with the center section being the...
Try the sealed then. If you feel you're lacking low end extension you might try to build a ported box to give you a little more output down low.
wu36ca
wu36ca
San Jose, CA
~Magick_Man~
pfft
    May 1, 2024
pfft
    May 1, 2024
