but it was working fine till i put the new amp in, so im going to look at it some more, but i dont see why it started doing this , but whether the sub is hooked up or not it will take the voltage from the system wont it? its not cuttiing out now, so i really dont kn ow,, im off to work now so be back latewr tonight
I just went back and re-read your first post. The part where you said "i tried it again at 17/40 and after a couple secs it poped again and came back on" is a very telling comment. This tells me your problem is not a shorted coil or melted tinsel lead (the most common shorts/electrical issues in a sub). Think about it, if the coil shorted out, the sub wouldn't come back on no matter what the volume control was set at. If a tinsel lead is melted in half, well same thing. The fact the sub cuts out but then comes back on when messing with the volume control tells me this is an electrical issue, not a mechanical failure within the speaker itself. The speaker is merely demonstrating the problem, as its the final link in the signal chain (in other words it outputs a noise for a problem upstream of it).
The fact that adjusting the volume lower made the sub 'pop' back on leads me to believe the amp is the culprit here. 1) Amp is drawing too much current, there by lowering the system voltage to a point that the amp goes into protection mode and shuts off until such a time as the voltage rises back to an acceptable level (like when the amp cuts off and you turn th volume down), or 2) the sub is showing the amplifier an impedance lower than it is stable for, which would also create a situation where the amp would go into protection when driven too hard, or 3) there is a wiring problem that is intensified when the bass vibrates the crap outta everything (like a lose wire that shorts against nearest metal surface when the bass vibrates it all), or 4) who knows, alot of other possibilities, but doesn't sound liek the speaker to me.
edit: btw you also said you turned the amp up a little when showing off to your friend. If you meant the gains, that's a real no-no. If you cannot get the output you want out of your system with the proper settings (especially amplifier gains), then you need a new setup, not to crank your gains. With the gains set properly, you can/will get the full output potential from your sub without distortion (or a minimal amount). If you crank your gains for more output, 1) you either didn't have them set correctly to begin with, shame on you, or 2) had them set correctly before, but now are sending a squared signal to your sub(s) thanks to cranking the gain higher, shame on you again. Set that gain correctly and leave it alone! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
