Xs Power d3400 vs Group 31 agm
  • 5
bgowdy
Heroes are remembered, but legends never die
Ok so i already have the XS power to be used as a secondary battery. I was thinking of switch to a group31 agm instead? I was told that smaller batteries charge faster then bigger one but i dont know how accurate that is.
What are your thoughs?
I was running a d3400 underhood for about a year before deciding to add another in the back. It's a beast of a battery, and I've worked mine pretty hard. In fact I haven't been able to completely drain one to the point where it won't start. I also have a bunch of off-road lighting as well as all my audio crap, so my batteries get worked pretty hard. There's been times I've pulled my d3400 out and ran the trolling motor at the lake for hours in the boat and ran the trolling motor for hours. When i threw it back in my jeep it cranked it right up. It's one of the best batteries you can buy.
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
568
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
745
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
567
bgowdy
bgowdy
Campbellsville, Ky
jordon
