box build for 4 dc audio xl 18's
xile
Hey guys. New here. Looking for a little help on designing a box for my 4 xl 18's. Its going in the back of a 01 suburban. Third row removed. Max width is 46" other than that plenty of room. My thoughts are a 22c.f. net box tuned around 32-35hz. Subs up port back. I've seen a few boxes with a slot port on the bottom I'd like to do a rectangle port mid box. Any thoughts on tuning and size or any ideas in general would be greatly appreciated. This is my first big build and want to do it right. Looking for a good daily sound with still being able to compete possibly. Power will be a dc 9k at 1ohm.
Thanks. Bigjohn
Why is your width 46"??? My 2002 Tahoe has 50" Inbetween the wheel well
Best score I got 4 18s on 8k was 153db. Sub up port back... Box was 22cubes with 180"-200" of port... I had a removable port and tried from 160"-400" of port and 180"-200 was the sweet spot tuned to 32hz
Got any pictures of the box. Would definitely like to see the removable port
Sent from my SAMSUNG-SGH-I317 using Tapatalk
Birch... Fvck mdf. And yes 2-3 layers and braced like a mofo
i know i know i'm not trying to beat you up, but i did some re-search today and hickory pecan and white oak stronger than birch.. its just to find them in anything but veneer and with soft cores..
also i agree with the lower profile. wider and deeper and no higher that back seat tends to work best. otherwise its start to sound trapped in the rear. im assuming its reshaping the transfer function acting almost as two separate variables(two cabins so to speak)?.. which brings me to this article.
http://www.rug.nl/research/portal/files/2907090/c6.pdf
that is why i recommend people get a sealed box with a critically damped alignment and run a few sweeps before and after the initial install and better help map the transfer function and any obstructions.
port up; port back; sub back; subs facing forwards; box shape and profile all affect transfer function..
i know i know i'm not trying to beat you up, but i did some re-search today and hickory pecan and white oak stronger than birch.. its just to find them in anything but veneer and with soft cores..also i agree with the lower profile. wider and deeper and no higher that back seat tends to work best. otherwise its start to sound trapped in the rear. im assuming its reshaping the transfer function acting almost as two separate variables(two cabins so to speak)?.. which brings me to this article.
port up port back sub back subs facing forwards box shape and profile all affect transfer function..
Yea but the birch is $42 a sheet at menards/Home Depot.. Those hickey and white oak prly cost arm and leg
http://www.workshoppages.com/ws/misc/wood-hardness-chart.pdf
Columbia Forest Products 3/4 in. x 4 ft. x 8 ft. Purebond Maple Plywood-263012 - The Home Depot
both are 50 bucks here.. none of them have really really hard cores. makes me wonder if stacking 2 1/2" sheets would be alot stronger than 1 which typically isnt the case but might be strictly because of the narrower cores in the 1/2".
nearly everywhere i called only had veneer and thats just two "skins" with a soft core..
i felt like a idiot on the phone with a local highend wood shop..
"we have a b2 beech veneer" i'm like i want the hardest **** *****. i gotta beat the block.. "excuse me?"
xile
xile
Lacon Ill.
Papermaker85
