WTF size speakers fit my car? Every1 says somethin different!
scheibler
I have a standard 1999 Nissan Maxima with stock non-bose system. Not sure what size speakers fit my car. Circuit City tells me that 6 1/2 is what I need, where as Crutchfield and cardomain say that I need to use 6 3/4 speakers. I don't want to order any speakersunless I am 100% positive they can directly replace the stock speakers in their same mounting holes. I just need four door speakers that will produce clear sound with subs pounding and not get washed out powered by a kendwood headunit with 22x4 rms.
I doubt you will find any speaker that will fit perfectly in your mounting holes. Take the speaker out and measure it's outmost diameter. More than likely its a 6.5" speaker.
even if they dont fit you can just cut out som baffles out of mdf. Its not hard at all. As long as the speaker isnt so deep that it goes too far into the door it will be fine. Width is nothing.
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
Tesla beat Edison. Why do you think we transmit high voltage ac? Cars are low voltage dc, which is absolute worst as far as efficiency goes, but...
61
It's a little overkill but hey... https://blackbrickaudio.com/collections/30-000w-amplifiers
scheibler
scheibler
St. Louis, MO
JoseMCeee
    May 12, 2024
Brendon Jenness
    May 11, 2024
