Wring a 1 ohm sub to a 2 ohm amp diagram?
where are you getting 4 wires to get 1ohm? it's duel 1ohm. that means each coil is 1 ohm. so it's not a 1ohm sub. it's a 1ohm duel voice coil sub. how are you confused about how to wire it? you can't get any easier than the pic i put up already.
what are you wiring the wires to though? The sub would only have 2 terminals on one side, and this is saying to wire the sub with one positive from one side going to one negative on the other side,a nd then run a wire form each side to your amp. Is this just a relative diagram?
your sub is a dual 1 ohm sub right?
that means the sub has 4 terminals...
if it doesn't then you misinformed us...
if it does the pic is exactly right...you have 2 wires to the amp from the sub and 1 wire jumper from 1 coil to the other on the sub ...just like the pic...
Just to clarify, was it supposed to go something like this?
And then I had the two wires from each side that werent connected to each other connected to the box, then the amp going to the box this is correct?
sizzl3r
sizzl3r
Minnesota
sizzl3r
ThxOne
    May 29, 2026
tyler0508
    May 27, 2026
