would this setup work?
peezyfeelingqueasy
39004
im sorry i’m very new to this stuff. is it ok that the amp is stronger than the RMS?
Yes, it is ok. The gains on the amp are like a volume knob. They control front and rear outputs independently.
Please never use this phrase ever again. As it is misleading and false.
Op you can use a more powerful amp than is required.
The gain knob on an amp allows you to increase the amps output until it matches the input of the headunits signal. Beyond the input signal you gain nothing but distortion. But you you keep it below the input signal you can throttle the amps output and in turn run less power than the amps rated output.
This is beneficial as it allows for headroom on dynamic music.
The gain knob can control the amps output wattage but only up to the point in which it matches the input signal. Anything below that is fine. Anything above is clipping.
What curt response would you use with someone whom knows how to do a basic install, but lacks a full grasp of what gains are for?
Pulled from the post I made earlier
"The gain knob on an amp allows you to increase the amps output until it matches the input of the headunits signal. Beyond the input signal you gain nothing but distortion. But if you keep it below the input signal you can throttle the amps output and in turn run less power than the amps rated output."
Or you could actually Google the gain knobs purpose and there are dozens of decent videos explaining it.
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
445
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
748
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
770
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
peezyfeelingqueasy
peezyfeelingqueasy
california
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
