Would someone do a math check? First box
Kaboob
LA
For two type r's, outside dimensions: 5/8 Fiberboard
33 inches long
16.1 inches high
Bottom depth 16 inches
Top depth 12 inches
5/8 Fiberboard divider,2 3x3x3 blocks inside for bolting
Should be about 3.4 cubic feet total (1.7 per chamber) when taking out the divider and blocks.
Two ports 3 inch diameter 9.9 inches long.
Thanks for the help guys.
Well I just used the recommendations from alpine so I didn't even check on the tuning. 3/4 MDF, ok let me redo some calculations here.
i did it very quickly, so dont hold me to it, but i got 1.66 ft. ^3 tuned to 31.02 Hz.
For each section right? Otherwise I seriously screwed up lol.
Ok here we go 3/4 MDF
33 inches long
16.1 inches high
Bottom depth 17 inches
Top depth 13 inches
3/4 MDF divider,2 3x3x3 blocks inside for bolting
3 inch diameter pvc 9.9 inches
1 more question, on cruthfield it says: Recommended Vented Box Volume: The vented box sizes recommended by Alpine range from 0.75 cu/ft to 2.0 cu/ft. Within this range, the ideal size recommended by Alpine is 1.7 cu/ft, so this is the enclosure recommended by Crutchfield. A slot port with the following dimensions should be used with the 1.7 cu/ft enclosure: W=12", H=1.25", L=21". If you cannot use a slot port in your enclosure, you will need a port tube with the following dimensions: Diameter=3", L=9.9".
So should the box be 1.7 without the ports?
Kaboob
Kaboob
LA
Kaboob
