would someone check my design for mistakes please
1.) sub mounting depth is 7.7" will 4.55" be good enough for space behind the sub? or do I need more??? I can make my box deeper if I have to but, I am trying to be able to get to my spare tire if I need to without disassembling my trunk...
It will be fine,some say an inch is all you need so 4.5 is plenty.
2.)my lip on my subs are 31/32" and not sure how to make it flush, I know to use a face board but not many pieces of lumber are 31/32" thick, do I add a mounting ring or ???..
1" face board?
3.)Does the hole in the separating wall between the 2 subs where the wires run does that need to be sealed or is it not necessary???
Cawk it up and it should be fine.
4.)I think I have hooked up my speakers correctly for 2 dual 2ohm speakers to run at 2ohms...Is the wiring correct???
Looks to be correct Wire each sub to 4ohms then straight the the terminal and check with a dmm.
5.) Is there something I forgot or messed up on..
My tip? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
muchos grassyass senior,
1.) cool thanks...
2.) yeah, I just will have a bunch of 3/4" MDF and to buy a sheet of 1" just for the face board is crappy, unless I just use 1" for it all...And the board is 1" the depth it needs to be is 31/32 so 1/32" will be above the sub, is that O.K.???
3.) so it will be sealed then, thanks
4.) will do thanks
5.) when you get to vegas I will buy you a lap dance at the rhino...
thanks, I want to get on this ASAP and didn't want to start it blind and possibly not be worth a ****... I know its a sealed box, but unless you are a wood worker this stuff is difficult to do correctly...
lvjeffro
lvjeffro
las vegas
DaGh0st
michigan born
    May 14, 2026
michigan born
    May 14, 2026
