Would my sub gain a bit of output with .10_.15 more cubic feet?
  • 5
it depends on the sub, phasing, cabin gain, loading and a ton of variables need not mention. alot of times its not too noticeable and other times it can mean finding that sweet spot. i think with that drive 1.75 is a good size and you will get better lowend output and loose a tad of output uptop..
I got a single cab truck. Cabin is 1.72 meters. The app said its around 20db cabin gain for most of the frequiensies.
My old Ford Contour had 20db of cabin gain compared to the plots in winisd. I would think a single cab truck would be more.
**** if it is even better since some of the music I listen to has not much bass lol.
---------- Post added at 10:26 AM ---------- Previous post was at 10:25 AM ----------
i think its gonna get bottom heavy. not IMO worth it in this case..
Like 30-50 hz range right?
318
378
521
624
BassDrop
BassDrop
SALINAS CA
hispls
    May 24, 2024
