working with a weak electrical system
Thats the point if im going to be a dumbass then i might as well be a dumbass so there you go, it did just as it was supposed to do.. Bye now.
Cool, I'll be sure to warn ppl about your dumbass advice on electrical next time you try to help someone. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
LOLZ!!!
Actually lets do some more math here..
My amp's max amp draw is 140 amps, my max power is 1400 w.. sooooo.... every 100 w takes 10amps to produce.. pretty simple..
My alt pushing 130 at 2,000 rotations at the shaft.. in the current con-fig im pulling about 78 amps for my main amp, and 20 amps for my second amp.. My car pulls about 60amps excluding radio, (only about 5 amps) my bat has a reserve power of 120amp CA of 1000 and CCA 800 the CAPCELL i wound up buying can discharge 800 amps @ 8 seconds, but real discharge is 50% at 400amps... so the capcell is infact supplying the extra power needed i need to run.. I have no dimming lights while listening to music not bass mekanik music but everyday driver music..... so proof as far as I am concerned is the pudding..
It works for me.. I see a difference between having no Capcell and having the capcell.. during musical peaks the power does not drop below 14V to the amp..
The capcell is way much better than a CAP.. a CAPCELL is jell filled just like the car audio bats, with the exception it is no where as good as a second battery.. and stores power and amperage much like a battery.
But you must have an upgraded alt for the second bat.. which defeats the point, for an everyday driver... so infact a CAPCELL is a much better way than a CAP aka CrAP but admit it is not as good as a battery.. but will in fact help someone like this guy.. with his power problem..
So think what you what.. I thought the way you did too, I asked the question though even at the risk of looking like a retard on another thread.. but I took a change.. after doing teh math and research on CAPS, CAPCELLS vs upgrading alt and second bat.
The CAPCELL is not a fix all.. and is not intended to be able to keep up during musical peaks lasting longer than 8 seconds.. its designed to deliver the power at short peaks and recharge in between peaks.. unlike a batt that has a slowwww recharge rate.. but store much more energy than a CrAP
So long story short the CAPCELL is providing the extra little bit of power i need for my amp to run with out straining for power.. so everyone can think what they want and make useless insults over the internet LOLZ but fact be told for someone that just needs alittle more power.. with out upgrading the alt, the CAPCELL can supply a little extra power.. it does on in my case..
and dont worry you dont have to waste time about how further retarded I am.. the math adds up.. no matter what you try to say against it.. its the internet, my word against you, my math based off technical data, vs your opinion.. who cares.. keep your dumb insults to your self...and I'm not going to waste any more of my time reading these posts.. LOLZ
Dude you clearly have no idea what you're talking about. Where did you get that it takes 10 amps to make 100 watts? Your capcell is not gel-celled like an agm batt. It is 6 1 farad capacitors in parallel. Sure it will act like a giant cap and will filter some power but it is no fix for having too small of an alt. You clearly have no idea what you're talking about. It is hilarious because I can tell you're serious and not joking.
Actually its from JBL's Engineer.. because i was tring to find an ALT to upgrade too and needed to know what i was pulling and that was their formula for their amp.. so what do i go by, an electrical engineer that supports the product or the local car audio guy that trys to sell Legacy amps as "the best on the market" or go by some random person that calls me an dumbass when he his self knows nothing about where i pulled the formula from..
wait im retarded.. i just responded after i said i was not LOL @ me for sure now! and P.S im not gonna argue any more.. arguing with someone is like running in the special Olympics, even if you win your still retarded :X
I'll ignore the fact that your grammar is atrocious, but I would really like to know exactly what formula your talking about? Please be as technical as possible.
THATpurpleKUSH
Fuckyou
THATpurpleKUSH
Slums of the Shaolin
bubbagumper6
