audioholic
not a moderator
Even when playing a burp, at or very near tuning, where excursion is at its minimum... the more the cone moves, the louder the setup will become. For the big time SPL guys, excursion and thermal power handling become a tightrope to walk. They want to acheive full excursion (or as close as possible), very near tuning, without melting the voice coil.
Even a sub with 100mm of xmax would only be able to put that all to use, in a vented SPL setup, if the coil was able to withstand the amazing amount of wattage it would take pumping through it in order to acheive full excursion while play very near tuning.
This is why nobody serious uses an 06 XXX in SPL, you simply cannot push it anywhere near its excursion limits at tuning without melting the coil first. I also believe this is exactly why DD has been so successful, they recognized this situation early on and designed a sub with this in mind (the 9500).
