Wondering If this is a good Set for Price
oh yea get D4, its how you wire the sub to your amp. since the ppi does most power at 2ohms youll want a D4 to wire down to 2 ohms at the amp
Keep in mind if you get 2 woofers that are d4 you'll end up wiring to 1ohm and need a diff amp
[quote name='C1500martin']Sub
SSA Store - SoundQubed HDS212 12 INCH SUBWOOFER (HDS212)
Amp
http://www.amazon.com/Precision-Pow...UTF8&qid=1433904920&sr=8-1&keywords=ppi+650.1
wiring kit
Amazon.com : KnuKonceptz KCA Complete 4 Gauge Amp Installation Kit : Vehicle Amplifier Wire And Wiring Kits : Car Electronics
@CSCStang for a custom ported enclosure
that is the cheapest itll get for bottom of the barrel quality stuff except the box thats top shelf if you get it from CSCStang[/QUOTE]
Pp amps worth a ***?
What vehicle are you trying to run? I do budget stuff for people a lot.... I'm the local go to for budget set ups lol. Not that I like it but it is what it is. So I have a lot of first hand experience with it.
I have a 2006 Mustang GT and the alternator amperage is 135. I'm running 3 amps totalling 1600 amps, driving 2 subs, 4 - 6x8 and 2 - 6.5. Ive...
Ive seen 3 370s in action at a couple Audio shows with a massive battery bank in Austin
759
276
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
715
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
801
Dingyps
Dingyps
Wisconsin
C1500martin
    May 24, 2024
