wiring my Speaker???
you mean dual coil hence the term Dual Voice Coil 2ohm or 4ohm it usually say somewhere on the sub dvc2, or dvc4, or dv2, or dv4, post what it says but i thought thos were svc but i bet they are probably dvc2
yea you are just running one of the vc if you run both voice coils it wil drop the ohm level on the amp and it will push more watts to your sub and usually using just one vc isn't a good idea
if you run a wire from one pos to the other and connect and do the same to the neg then run a wire for the pos and negative it will drop the ohm level from like probably 4-2 0r 8-4 or 2-1 so
are you just running one sub
It's quite difficult to point you in the right direction without knowing a couple important factors.
if you can, figure out:
Number of subwoofers: 1, 2?
Voice Coil Configuration: Dual 2, Dual 4
Amplifier specifications: Monoblock, 2 channel, 1 ohm stable?
From the OP's first post it sounds like he has a quad coil, NOT dvc.
Post specs of the sub and amp so we can help you correctly. Ignore all above posts because they do not have enough information.
JarrettCTE
Nissan Altima
JarrettCTE
New Castle,Delaware
DB_DRAG_SPL
