2000 Silverado system Help
00loudchevy
Ok i have two 10" solo barics in a subthump box powered by an 2300 watt audiobahn amp wired 2 channel at 2 ohms with one of the jensens flip out tv h.u's Heres the problem Its not that great sounding i get alot of clipping (is there a way to fix that?) (cross over, anything?) Other then that i did the big 3 upgrade to help with current flow, but is this problem caused by the h.u. or the box? It had around .92 cf of air and that like right in the middle for the solo barics? //content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
Check your gains on your amp, and maybe read up on the gain setting tutorial to reset them so you get them right without overdriving the amp causing a dirty signal.
here's some good reading to understand setting up your amp, http://www.caraudio.com/forum/showthread.php?t=63933&highlight=gain+setting+tutorial
Not sure what the pre-out voltage is from the Jensen but I'm guessing its fairly low meaning your gain will need to be up higher than it would with a HU that has higher pre-out voltage.
00loudchevy
00loudchevy
buffalo
jdc753
