Wiring monoblock amplifier to 1-ohm (2 subs)
  • 5
Lennox
wiringdiagram_zpsa18d02cc.png~original
So this is what I've got along with approximately 15 feet of speaker wire. Amp is Hifonics Glx1400.1D, and subs are Pioneer TS-W3003D4 (Dual 4-ohm). How do I wire these to one ohm when the box has terminals?
Every diagram I see has amp wired straight to subs and doesn't have terminals //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif.
Also each sub has a seperate chamber so wires can't go from sub to sub. Is there a way to get this wired to 1-ohm? Thanks for you help guys.
wire both of sub #1 's positives to the same positive terminal, negatives to the same negative
do the same for sub #2
and on the outside of the box, wire both terminals up to the same polarity on the amplifier (negative to negative/pos to pos
wire all the positives on the sub to the positive on the terminal and then all the positives on the terminals to positive on the amp. Do the same for the negatives
The terminals on the amplifier are wired in parallel internally, so this is easy. Wire both voice coils of a sub in parallel to that sub's terminal. Wire the terminal to the amp's outputs. Like this...
SUB1_VC1(+) wired to SUB1_VC2(+) wired to terminal(+) wired to amp(+)
SUB1_VC1(-) wired to SUB1_VC2(-) wired to terminal(-) wired to amp(-)
SUB2_VC1(+) wired to SUB2_VC2(+) wired to terminal(+) wired to amp(+)
SUB2_VC1(-) wired to SUB2_VC2(-) wired to terminal(-) wired to amp(-)
So this will run the amp at 1-ohm?
What you drew will work and is electrically correct and will result in a 1-ohm load on the amp. But, like CCooney said, it might be easier to jumper both VC(+)s together and then connect one wire to the terminal(+) inside the box - same for the VC(-)s. Do it just like the Sonic Diagram. Solder wires at the VCs.
I agree with others, just buy the OFC. My last wiring was oversized CCA, and while it still works, and looked okay when I peeled the heat shrink...
120
189
Box rise, more accurately, impedance rise, is the reactive load changes the woofer exhibits at different frequencies and it will happen, it's...
429
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
343
Lennox
Lennox
Mount Vernon, OH
Jepalan
