wiring Kicker l7 w/ Xtant
  • 3
specific112
Ok my equipment is this: 2 600 watt 10" Kicker Solo Baric L7's in a sealed enclosure, and an Xtant 1001dx one channel amplifier.
My question is how to wire the subs, parallel or series? The other question I have is should I run 4 ohms and 250 watts, 2 ohms and 500 watts, or 1 ohm and 1000 watts? I know absolutely nothing about this stuff. I just know I like really clean liquid bass. Thanks for the input (hopefully).
Originally posted by JTz62 Well first off, do you know if you have dual 4 or dual 2 ohm voice coils? Also, does the Xtant put out max power at 2 ohms or 1 ohm?
I'm not sure about what max power is really referring to, but I just know that it is 1000 watts at a 1 ohm. And I have the dual 4 ohm voice coils.
Originally posted by specific112 I just double checked and the subs are actually dual 2 ohm
You really need dual 4 ohm subs to get the full output of your amp. The best thing you can do is run it at 2 ohms with those subs. If you can't exchange them for dual 4's then wire them in series-parallel. That means series each speaker, then parallel the speaker wires at the amp. This will give you a 2 ohm mono load.
the 1001 could probly run fine at .5 ohms (both subs wired in parallel) if you really wanted it to. You'd have to be real careful though. The amp should be stable but you should also consider the power your sending to those subs. I have heard of the 1001 delivering 2500 watts into .5 an ohm and even for those subs . . . thats a lot of power. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
331
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
410
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
503
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
456
specific112
specific112
Seattle, WA
mr4pto
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
