Wiring help.
Is it possible to wire 12 dual 4 ohm subs to one monoblock amp and get a final impedance of 1 ohm or 2 ohms?? If so how would i do this?
+ from amp to + of voice coil 1 jump a wire to + of voice coil 2. Do the same for the -. This is parallel and will give you 2 ohm load. You can't wire one d4 to 1 ohm.
Break them into two groups of 6.
For each group --
Coils parallel for 2.
Each pair of subs parallel for 1. Now you have three 1 ohm loads.
Wire the three 1 ohm loads in series for 3, then wire each bank of 6 subs (3 ohms each) parallel for 1.5 total.
vandrew0320
vandrew0320
United States
n2audio
AJ (ACE)
    Jun 28, 2026
