wiring help
ok for the 4 ohm if you wire all voice coils in series giveing you 6 8 ohm subs when you wire teh subs in parallel your gona get a 1.3 ohm load
if you do the voice coils in parallel then the subs also in parallel you get a .33 ohm load
if you do voice coils in parallel then subs in series you get a 12 ohm load haha
and if you do it all in series you get a 48 ohm load haha just guessing but thats what your looking for right??? jk
for the 2 ohm voice coils in series then subs parallel gets you a .66 ohm load
if you do voice coils in parallel then subs in series you get a 6 ohm load
everything in series you get a 24 ohm load
everything in parallel you get a .0098 ohm load
so yeah hope that helps man
depending on what ohm load you wan final you can make your decision from there. what amp you gona be using???
arntsmag
arntsmag
stl
cirv908
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
