Wiring help?
in phase means your subs will hit at the same time, so that when one sub is out the other sub is also out, instead of having one push out and one retract in. one way you can make sure you do this is to wire them both the same way. and then if you still have problems it there would be setting on your HU and amps(if equipped) to do so.
newyork2050
newyork2050
ny
blackbonnie
michigan born
    May 14, 2026
michigan born
    May 14, 2026
