wiring help
mike75356
OK so im confused i understand the basic wiring of subs at 1 ohm and 2 ohms and so on and so on. What i dont get it is what do you do when you want to wire a sub to an odd impedance i guess you would say... Like say i wanted to wire in a kicker 2500.1 to a dual .7 mt, how would you go about doing so? Or if you wanted to wire a 13 w7 to 3 ohms? Which one of the voicecoil options would i use in the voicecoil wiring sticky?
as for a 13w7, it's dual 1.5 so you'd either wire it in parallel for 3 ohms and series for .75 (i think. i'm still confused about which is series and parallel).
Got is *** backwards.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
And as per the stickies, they are not only good for those particular coil configurations. That theory applies to all "speaker" wiring. I will give ya something that is very useful, if you don't understand, ask and I will explain it. If you have taken ALGII in HS then you should be able to do this.
For wiring in series:
RT=R1+R2+R3+Rn
Where n is any integer representing the resistance of the last coil.
For wiring in parallel
1 / RT = 1 / R1 + 1 / R2 + 1 / Rn
Where n is again, any integer representing the resistance of the last coil.
mike75356
mike75356
pittsburgh
RandyJ
