wiring help**
like
lets say your looking at the subs like so:
1.take one of the positive terminals on the 1st sub, then connect it to a positive terminal on the 2nd sub
2. Do the same with the negative (be sure its not on the same voice coil)
3. take the left over terminals (should be + and - on different sides of the sub) on each sub and wire them accordingly
i hope that made sense
step 3- it what gets me it show that i connect a wire from the + to the - on the same sub...or do i connect 1 + from one sub and connect it to the other + on the other sub and same for the other sub?? is that how
k thats what i did, but before it blew it wasnt as loud as it is now...should i change the gain setting?
EDIT:but wait you know how on the d2's how there is 2 terminals on each side of the sub... so say i just connect a wire from the + and then connect it to the - on that same side or do i connect it from one terminal to the otherside terminal?
did you use a dmm to set the gains?
huh?
cfizzle
cfizzle
Detroit, MI
cfizzle
