Wiring help and suggestions please
iThorr
Hi, I am going to be installing some things to my car and I would like some help on what gauge wires go to each piece that i will be installing.
I will be installing:
1 Boss 10 Farad Capcitor
1 Pyle 2-Way Electronic Crossover Network
2 Pyle 6.5" 300 Watt Two-Way Speaker (1 in each door)
2 Lanzar Optidrive 200 Watt Heavy Duty Aluminum Super Tweeter (1 in each door)
2 Crunch PowerZone P1100.2 1100 Maxx Watt Power A/B Class Two-Channel Amplifier (1 for speakers/tweeters and 1 for subs.)
I already have 2 1000w subs and a Boss BV9560B head unit
I am pretty sure I understand what wires to what in the correct order, I am just not sure what gauge wires to use, if I would use one size overall or separate sizes for different connections.
Any help or suggestions would be much appreciated, thank you so much for your time //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
//content.invisioncic.com/y282845/emoticons/word.gif.64b12e39f936af3b4fff38a1c0bd0244.gif get a 100ft roll of 14ga for all your speakers is what i use, and small roll/25ft of either 10 or 12ga for the subs,i use agu fused dist block for my amps power,anl for power run, and extra battery,rather than a cap.running that much juice,you will need to look into a ho alternator as well, as doing the big three,in my opinion.
So also I would need to have another battery and alternator to charge that battery?
iThorr
iThorr
Orlando, FL
iThorr
