So after reading my PPI a404.2 manual I still couldn't find out if wiring up two 4-ohm Component sets will get me 2-ohms Stereo. Below is my diagram. Will that give me 2ohms from the 4-channel amp?
If this helps or makes any sense, there is a button that says "FRONT/REAR" Combined". The manual says this:
"On the left side panel of 4-channel amps is a "2/4 way" switch. If both "Input-1" and "Input-2" are to receive the same input signal, place the "2/4 way" witch in the ON position. This will parallel the inputs together internally in the amp. In this mode, either set of inputs may be used."
Does this mean it will parallel my 4 ohm speakers into 2 ohms? If so, is the way I have it wired correct? Any help will be greatly appreciated!
~REVNU
~REVNU
